Old 08-21-2007, 07:10 PM   #1
blkboxster
Guest
Posts: n/a
How to get best 0-60 times
my G-tech should be arriving soon, any tips to get a good 0-60 time, launch rpm, when to shift, etc???
and what times do you think i will get, so i can compare when i get the real results
im guessing between 6.8-7.0sec tell me what you think, i most likely will launch like i did on my vid in my sig, or is that just to much?
Old 08-21-2007, 08:12 PM   #2
boxsterz
Guest
Posts: n/a
Traction control/PSM off will reduce times by more than .5 sec. Before that dawned on me I was about a full second off and made me really wonder.
I didn't want to beat up my clutch too bad, but slipping it slightly is quicker, however not as consistent.... so if you want uniform results, dumping at say 2500 might be the way to go and hammer it to redline.
I could pretty much duplicate published times with full tank, PSM off, 2200 launches with some slip, and redline shifts.
On one lauch, I revved it too high while dumping the clutch which resulted in severe axle hop all the way to redline, it was so violent my full coke-cola jumped out of the cup holder and onto the seat! Thank god it wasn't opened yet That run got me a 10.XX ET 1/4 mile
My best real time was 5.579, 0-60; and 14.031, 1/4. I could've shifted a hair faster, but I don't like abusing the equipment. If I drove it like I stole it, I suspect I could take another .2 sec off.
Old 08-21-2007, 08:17 PM   #3
This is the approach taken by the testers at Automobile magazine:
TESTING PROCEDURES AND PHILOSOPHY
Equipment: VBOX II GPS-based system manufactured by Racelogic, Buckingham, England. (You can verify our results by buying your own at www.racelogic.co.uk for $11,800.) A Doppler shift applied to radio signals received from the US Department of Defense Global Positioning System satellites yields velocity, position, and other information which is recorded for analysis.
Vehicle state: Driver (no passengers), full fuel tank, break-in mileage.
Driver: In the interests of consistency and comparability, all formal testing is conducted by Don Sherman, Automobile Magazine's technical editor. He's been doing this for 34 years.
Acceleration test: Standing start with aggressive clutch engagement (vehicles equipped with manual transmission) or brake torque (vehicles equipped with automatic transmission). Traction and stability control systems are disabled when possible. An appropriate amount of wheel spin is encouraged to obtain peak performance. Lift-throttle up-shifts are rapidly executed with redlines observed. Drag strip "roll out" time and distance are NOT subtracted from published results.
Passing acceleration: With the transmission in third gear (manual-shift vehicles) or drive (automatic-equipped vehicles), and the vehicle cruising at 30mph, the time needed to accelerate to 70mph is measured. Corrections applied to all acceleration figures adjust results to standard weather conditions (60 degrees F, 29.92 in. mercury barometric pressure).
Braking: A pressure switch located on the brake pedal initiates recording of activation speed, deceleration rate, and distance information. Braking distance is mathematically adjusted to a 70-mph initiation speed. The deceleration rate reported is the peak g's measured during a stop.
Cornering: The test car is accelerated to the adhesion limit on a 400-foot-diameter skid pad circle. The peak g's reported are the averages observed during one-second intervals in each direction.
Speed in gears: The maximum observed velocity without exceeding the engine's redline rpm.
Philosophy: Automobile tests cars for a variety of reasons. While many makers offer a few snippets of acceleration, top-speed, and gas-mileage information, many do not. Conducting our own tests fills in gaps and adds trustworthy information about passing ability, cornering grip, and stopping performance. Having accurate performance profiles helps us pass judgment when we compare one contender to the next or draw conclusions at the end of a Four Seasons evaluation. Since there is no industry-wide standard for car testing, every maker has its own pet procedures. Some test with less than a full tank of fuel, some with two passengers and luggage aboard. Doing our own tests is the only means of leveling the playing field. Some publications strive for the quickest, fastest, or most spectacular results. We make no attempt to emulate quarter-mile drag strip results by subtracting the roll-out portion (the 0.3-0.4 seconds required to move the first foot) of the acceleration run. Drag strips divulge nothing but the speed achieved near the end of the quarter mile and the time required to accelerate that distance. Since the strip reports no other time-to-speed information, subtracting roll-out from 0-60 mph results is never warranted. Many magazines do adjust all of their acceleration results by subtracting the roll-out. We do not because, even though that yields quicker, more tantalizing performance figures, it presents a less accurate picture of the car's abilities.
http://i7.tinypic.com/24ovngk.jpghttp://i7.tinypic.com/24ow0id.jpg
06 987S- Sold
Carrara White / Black / Black/Stone Grey Two-tone
05 987 5-speed - Sold
Midnight Blue Metallic / Metropol Blue / Sand Beige
06 MB SLK350- Lease escapee
Iridium Silver Metallic / Black
We've heard that a million monkeys at a million keyboards could produce the complete works of Shakespeare; now, thanks to the Internet, we know that is not true. - Robert Wilensky
SD987 is offline   Reply With Quote
Old 08-22-2007, 11:34 AM   #4
blkboxster
Guest
Posts: n/a
thanks , anyone else have an input?
Old 08-22-2007, 12:39 PM   #5
Perfectlap's Avatar
remove the passenger seat, floor mats, spare tire, get a Braile battery, run with only 1/8 tankful, wear light shoes err no shoes, remove watch, belt, roll up windows and raise top, wax the car momments before launch, and run with a tail wind and urinate before you get in the car.
take the g-tech to the local PCA or SCCA autocross. that would be much more intersting than 0-60 runs.
Pocono South Lap
BORN: March 2000 - FINLAND
Old 08-22-2007, 12:43 PM   #6
Originally Posted by Perfectlap
... and urinate before you get in the car.
I have found that my 0-60 times are far better when I have to pee real bad. It motivates me to accellerate as fast as possible to get to a toilet. :dance:
Old 08-22-2007, 01:01 PM   #7
blkboxster
Guest
Posts: n/a
great point, i wont piss till tomorrow
Old 08-22-2007, 07:03 PM   #8
Try revving to 4 maybe 5 grand and slip the clutch without inducing too much wheelspin/hop for the best times. You have to find the right balance between letting the clutch out too fast vs too slow.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 08-22-2007, 08:19 PM   #9
Send a message via AIM to djomlas
if you want some GREAT traction, on the side of highways, those bumpy things to wake you up if you fall asleep and get too close to the wall, hehe.
i actually pulled over once on the way to the track, and when leaving we did the test, 2 people in the car, and wow was the 0-60 faster, mad grip...just don't go too long on the side.
but, that doesn't count hehe, or does it
http://i34.tinypic.com/157yslk.jpg
"I couldn't find the sports car of my dreams, so I built it myself." ~F. Porsche
Gemballa springs::litronics::Eurotech 18s(275/225)::B&M::MOMO wheel::
exhaust cutouts::EVOcoldair intake::OEM smoked tails & sidemarkers::
colormatched bumperettes::Top Speed Pro-1 exhaust::
my cardomain/pictures page
djomlas is offline   Reply With Quote
