Old 08-18-2007, 07:04 AM   #1
9eighty6's Avatar
986 to 996 gague cluster conversion
Hi All -
Does anybody know the difficulty level / possibility of converting my gauge cluster from my Boxster ('01) and convert it to the 5-gauge 996 panel?
Thanks!
9eighty6 is offline   Reply With Quote
Old 08-18-2007, 07:30 AM   #2
I believe there is a pretty good writeup over at RennTech. The difficulty level is fairly easy... If I remember correctly, it is a pretty straight swap, though you'll need to modify your cluster trim, or get one that fits the 5 pod unit, and then add a couple extra wires for the oil gauge, etc.
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
Old 08-18-2007, 08:42 AM   #3
http://www.renntech.org/forums/index.php?showtopic=12805&st=20
Mike
04 Boxster S - Basalt/Savanna, 6sp, Carrera lites, hardtop
70 914-6 - Black over tan, original/stock
PCA since 1970
70Sixter is offline   Reply With Quote
