Old 08-12-2007, 03:26 PM   #1
O2 Sensor needs replacement
2000 Boxster
DME said that an O2 sensor is bad.
How long can I drive with a bad O2 sensor? What bad could it do to the car?
khaluk is offline   Reply With Quote
Old 08-12-2007, 03:40 PM   #2
no; there is a pad wear light on the dash for that purpose. if your check engine light is on, you have another issue. get the codes read and post them here.
insite
'99 Boxster
3.4L Conversion
Old 08-13-2007, 02:28 PM   #3
The engine light was on due to a O2 sensor issue.
After resetting the engine light, the mechanic said that I should drive around for a while because they sometimes tend to act funny(sensitive). I have been driving it for about 50 miles so far and no light, no problems!
thanks,
Old 08-13-2007, 02:35 PM   #4
thanks,
The CEL doesn't come on for nothing. If it came on for an o2 sensor issue,it will come back in time,it's just a matter of how long.
They aren't that much,$100/each & 1-2 hours to install all four.
Old 08-13-2007, 02:41 PM   #5
It looks easier than that from what I can see. Unplug the old the old at one end, unscrew the other and it's out. I would say 20 min tops for 4 sensors, but maybe there is more to it than it looks.
Old 08-13-2007, 02:51 PM   #6
20minutes if you have access to a lift,I don't. I always add another 30-45minutes to get the jacks,jack stands & all my other tool crap together and cleaned up.
