Old 07-20-2007, 01:20 PM   #1
undercarriage shroud
I am not sure what this part is called, but its large plastic pieces that protect the undercarriage. Mine is cracked and I am looking to replace it. Any ideas.. or sources? please advise
Theorg is offline   Reply With Quote
Old 07-20-2007, 01:26 PM   #2
Send a message via MSN to CJ_Boxster
http://www.partsheaven.com/pages/wrecks.html
they should have them. alittle FYI for yeah, there are 3 peices, the front(suspension + gas tank Cover) the middle (Fuellines Cover) and then rear (Front engine Cover).
You'd have to specify.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 07-20-2007, 01:31 PM   #3
thank you Carlos ... this is a lot more info. than I already had.
Old 07-25-2007, 03:59 AM   #4
my car is missing these underside covers... is that a problem? should i buy them?
mjstallion is offline   Reply With Quote
Old 07-25-2007, 04:19 AM   #5
07 Carrera S Cab
Boxtaboy's Avatar
First off, be aware that there aren't underbody panels that cover the entire underside of the car, just a few strategically placed black plastic panels in certain locations in the front section, midsection (drivers side to cover fuel lines/coolant lines). The rear section for the most part is left uncovered.
I'd double check at the dealer parts dept. which parts you really are missing. If you are missing some underbody panels, do get them replaced, as they serve two purposes: to smooth out the air flow below the car, and to protect vital fluid lines from road debris.
