Old 07-18-2007, 01:38 PM   #1
Will this lighwieght battery work good for my 987 base?
I have a 987 Base triptronic, not the fastest , so I plan to put a AWE exhaust, (15 pounds lighter than stock) a lightweight battery (almost 30 pounds lighetr).
Evo intake and chip GIAC.
I used the car mainly on Sunday morning drives in the twisty mountains.
Will this battery work for my car?
PC925T
Price $134.99
# 925 cranking amps for 5 seconds
# 870 cranking amps fpr 10 seconds
# 765 cranking amps or 20 seconds
# Short circuit current over 2400A
# 28 amp hours
# 50 minute reserve capacity with 25amp load
# Female brass terminal w/M6 SS bolt
# Length 6 15/32"
# Width 6 7/8"
# Height 4 7/8"
# Weighs 23 lbs
Package Details
Weight: 23
Sku: EL-PC-925T
Quantity:
Color:
motoadve is offline   Reply With Quote
Old 07-18-2007, 02:25 PM   #2
Send a message via MSN to CJ_Boxster
probably not since the battery wires on the porsches only accept male terminals and the battery you mention comes with female terminals. U would have to buy female to male terminal adapters to make it fit in the porsche.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 07-18-2007, 02:29 PM   #3
Specs look like a motorcycle battery.
You can always make your own lightweight battery....
Tool Pants is offline   Reply With Quote
Old 07-18-2007, 02:33 PM   #4
How about the power of the battery?
Where can I get the adaptors?
Old 07-18-2007, 02:37 PM   #5
Well assuming the female terminals are similar to the female terminals used on automotive batterys for cars like the Iroc Camero, you can get them at any autoparts store like pep boys or autozone.
As far as power, i have no idea.
Carlos J Cazares
Old 07-18-2007, 02:37 PM   #6
Will this one be better?
http://www.jegs.com/webapp/wcs/stores/servlet/product_10001_10002_841891_-1
Im worried about the power mostly
Old 07-18-2007, 02:44 PM   #7
Those look fine but i dont know anything when it comes to ampage.
You'd probably have some trouble getting the factory mount to hold on to that battery.
Carlos J Cazares
Old 07-18-2007, 04:56 PM   #8
They sell an adapter
Old 07-18-2007, 05:42 PM   #9
Well your covered there, try asking on the renntech forum, Loren would likely answer question in a flash.
Carlos J Cazares
