07-02-2007, 08:59 PM
left top down in rain, plz help
Hello,
I recently borrowed my friend's 01 boxster for July 4, and I accidently left the top down in the rain. Now the car will not start. I put the top up and the electronics and dash lights work, but when you go and turn the key I get nothing. I tried pumping the clutch a few times, but still get the same thing. Any ideas out there? Any help would be appreciated.
Thx,
David
07-02-2007, 09:02 PM
Sounds like the "uber" control unit under the drivers seat got fried. Basically your screwed hardcore. I think it costs thousand dollars or something. Take it to a dealer.
07-02-2007, 09:28 PM
thx for the help.....even though that is not what I wanted to hear.
07-02-2007, 10:49 PM
anyone know how much the control unit under the driver's seat costs?
07-03-2007, 03:15 AM
This sounds really stupid I know, but did you check the steering wheel to see if it is locked or unlocked? This can also lead to the same symptoms you are describing. Good Luck.
07-03-2007, 06:11 AM
Good point. Don't forget that you have to push the clutch all the way to the floor as well.
http://www.martinlansky.com/Coppermi...01/W_humps.jpg
'03 Midnight Blue
18" Chromes//Drilled and slotted rotors//pedal upgrade//Alum. Door sills//KSPORT Coilovers//Short Shifter/Strut braces/Clear sides/Hard Top/Speedster humps/Intake//Leather GT3 seats/REVO chip with SPS2
'04 CLK55 AMG 367HP!
'86 944 Guards Red & MINT!
'69 911 Black
PCA Member -Northern Ohio
Cancer Survivor
07-03-2007, 06:26 AM
Im curious, have you mentioned what happened to the car to your friend yet? If you have some torqx screw drivers or sockets, i'd remove the drivers seat and see if theres moister on the control unit or not... If not, try to take a blow drier to the steering colum and maybe the ignition keyhole... could have damaged or shorted that out with water.... Also, check the fuse box for blown fuses and replace all burnt out fuses.
07-03-2007, 06:34 AM
if it didnt rain too heavily, i think you should be fine. the front windshield is at such an angle that ir really protects almost everything on/near the dash but i dont know what is under the car seats. like someone said, did you press the clutch down when you turn the ignition key? yes, also check for any burnt fuses. unless it rained and poured for several hours and everything is soaking wet, i can't see how the car got screwed up. let us know.
07-03-2007, 09:27 AM
Move the driver's seat forward and feel under it. Is it wet? If so, dry it out.
I had a similar problem, the drain on the driver's side was plugged, and it leaked into the cabin. The car operated fine, but after running a couple errands, everything would work, but the starter wouldn't engage. Likely the starter kill circuit was activated. Dried it out and it's worked fine since.
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
07-03-2007, 11:07 AM
To be the first in this post to say this..... this is why I don't let people borrow my cars! Have you told your friend about this yet?
It sounds like the immobilizer (under the driver seat) is fried. The windshield should have saved most of the dash components, but I'm guessing its damp under the seat and you fried that black box.
Patrick
07-08-2007, 04:29 PM
update!!!!
Well, here is the update. I left the doors open and put a fan inside the car for three days, trying to start the car each day. Finally on the third day it started right up. I let my friend know what happened and he wasn't as mad as I thought. I told him that I would pay if he wanted to take it to the dealer but he says everything it running fine now. And yes, he is a very good friend. Thanks again for everyone's help.
