Old 06-30-2007, 03:07 AM   #2
There should not be big gaps or uneven. Having or not having radio code does not impact top. Not to sound simplistic, but are you sure the e-brake is pulled up and light showing as such on dash? What about the micro switch where the center latch goes - do you have a the infamous red clip & forgot to move it? I sometimes do (especially since I painted mine black to match).
If you e-brake light is not showing on the dash, your switch there could be going bad. Give it a few easy pulls (one or two notches) to see if that works. If not, then try a few hard pulls.
Since you're not getting any top motor movement or sound, I suspect it's either the switch in the e-brake or micro switch at center latch.
