Old 06-24-2007, 12:00 PM   #6
Originally Posted by mikes_box
a good way to check if your alarm is still operable is to see if all the doors lock when you lock and unlock it using the key.....the central locking system runs through the alarm so if you lock the car and the other doors/trunk don't lock then its the alarm....if they all lock then its just the remote needs to be reprogrammed...also when you lock the car check the led on the center to see if it turns on.... hopes it helps...
Thanks Mike. Let's see, the LED in the center still blinks when I lock the doors. All the doors and latches are locked when I lock the key. So I guess the key needs to reprogrammed? I don't understand why it would get "unprogrammed".
conradtan is offline   Reply With Quote
