Old 06-09-2007, 02:12 PM   #1
Help Please
Check engine light came on late yesterday. Drove fine today BUT on freeway for a brief period I was putting out massive white exhaust. Mass Air Meter?
slick is offline   Reply With Quote
Old 06-10-2007, 06:01 AM   #2
more likely it's your AOS (glorified PCV valve) based on lots of smoke. Go to autozone and get the codes read for free and post the #s they give you.
Can you open the oil filler cap easily when running? Pull the j-tube from the throttle body intake and see if oil is puddling there. If so, definitely AOS.
Do a search in the archives for it and how to replace. Not easy, but a DIY for $100 vs dealer replace at $300+.
Let us know.
Old 06-10-2007, 08:41 AM   #3
I trust your knowledge but not my mechanical skills. It's a Porsche cert used and I think they will cover at least part of the repair.
Old 06-11-2007, 02:05 PM   #4
Burg Boxster
You were correct. Fortunately it's covered.
Old 06-12-2007, 03:38 AM   #5
sorry I was correct I guess, but glad it's covered.
