06-08-2007, 09:16 AM
reseting the engine check light
Anyone know how to reset the engine check light,
i already tried unplugging the battery for a day. Turned off for a few days, then turned right back on. Thanks
06-08-2007, 09:19 AM
Not to be a jerk... Do you know why the cell is on? Def. shoul have it checked out. Go to autozone, they do it for free.
06-08-2007, 10:22 AM
You can purchase an OBDII code reader for under a $100 just about anywhere. I bought one at Walmart for about $75. It will read the code on a small display so you get some idea of why the CEL is tripping. The device also allows you to clear the code.
2000 Black Boxster S
EVO Intake & GIAC Tuning
Headers & Porsche Sport Exhaust System
ROW M030 Suspension
Front & Rear Strut Braces
B&M Short Shift & EVO Billet Linkage
06-08-2007, 10:34 AM
ummm, its going to keep turning on until you fix whatever the hell is making it turn on. Take Jaay and Steve00's advice & get it scanned by an ODBII scanner at autozone... its free. Write down the P-code or codes and bring them here and we can help yah out.
06-08-2007, 12:04 PM
Figure out what it is before you reset it.
Them engineers at Porsche didn't engineer lights that turn on for no damn reason!
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
06-08-2007, 12:21 PM
You may be used to dash lights that say
"Maint Required" or something similar which some manufacturers put on their cars to remind you of the factory service interval.
Porsche's CEL is different, it is triggered when something goes wrong and the "codes" people talk of are clues to what is wrong and how serious it is. They can range from "trivial" to "don't drive this or you risk blowing up your engine.
So the advice here to find out the problem that is causing the CEL is spot on. And you do that by getting the code read and then:
calling a Porsche dealer
or posting the codes here.
To get the codes read, borrow or buy a reader or see if one of the auto parts stores will read the codes for you. The code readers are simple plug in devices and the socket is the the left of the steering wheel.
Porsche CELs aren't things to be ignored until you know what caused them.
Have you priced a Porsche engine recently?
06-13-2007, 03:39 PM
codes
The code readout for my car was P1128 and p1130
Anyone can help me, and tell me whats wrong? Thanks a Whole Lot
06-13-2007, 03:49 PM
Those codes are for your oxygen sensors. They're about $113 each from www.oxygensensors.com and you can change them yourself in 45 minutes. It's real easy. However, you must do all four at once as they don't play nicely when some are old and one or two are new.
For more information on CE light codes, check the page on my web site. I have them all listed.
06-13-2007, 04:07 PM
True,
but when you get readouts on both cylinder banks at the same time I usually first suspect a problem which affects both cylinder banks. It's less likely that Oxygen sensors on both sides die at the same time and more likely that one COMMON component bit the dust. The MAF might be the culprit here...
There are many threads about diagnosing an fixing MAF related problems, simply search the forum for MAF
06-13-2007, 06:04 PM
Ok, you know what the codes are.
I had a P1129 back in January or February... cleared it and it never came back.
I would clear it and drive the car. If the codes return, you would probably then do well to look into the O2 sensors.
06-14-2007, 01:58 PM
MAss Airflow Sensor
YEa i thought it was the Mass Airflow Sensor too!! but my mechanic insisted on the fact that i was o2 sensors. I ended up spending 600 fixing the first two o2 sensors, and the light is still on!!! do u think i should be the MAss Airflow Sensor??
06-14-2007, 02:01 PM
The whole job cost me 600 to do all 4 sensors and the mass air. I got the mass air from departstop.com and the sensor (buildable ones) from NAPA.
06-15-2007, 08:52 AM
I had codes P1128 and P1130. Replaced the mass air flow sensor and no more CEL. That was about a year ago.
ROW M030 Suspension
06-15-2007, 09:41 AM
Where,
I have a PDT/PST at my facility, and can clear your codes. Feel free to visit the shop, since you live in the same city that I do. Let me know if you are interested.
Bisimoto Engineering
2001 modified Boxster S, slate grey, red interior
06-18-2007, 11:39 AM
Yea! do u think u can recheck the light for me and see if there is any other problems. Cause i have changed the O2 sensors already THanks
07-02-2007, 04:29 PM
So here is the thing. I ended up spending another 250 dollars getting my car fully checked for the problem. The guy told me that of the two codes p1128 and p1130 there was a total of seven possible faults. He said after checking the faults which included the MAF, Oxygen Sensors, the Manifold, Oil Pressure ect.... He came to conclusion that my Custom Magnaflow Exhaust was causing some sort of back pressure that the car was not use to therefore causing the engine check light to turn on. CAn this really happen. I only swapped out the 3 inch in length piping after the 4 cats and the mufflers and the tips. NO change in between cats and headers. Can anyone give me some advice, or anything.
07-03-2007, 01:18 AM
Given the fact that numerous types of exhaust systems have been installed on Boxsters with no CELs, I'd say your mechanic is probably wrong.
The codes you pulled can be caused by a bad MAF or a simple vacuum leak. What did yuor mechanic do to rule out the MAF or a vacuum leak as the culprit? I would strongly suggest, before you spend any more money throwing parts at this thing, you put the top in the service position:
Moving the Convertible Top into the Service Position
....and inspect the oil seperator connections, vacuum hoses, and the intake manifold plumbing. There's a bellows at the base of the oil seperator that often tears, causing codes similar to what you have.
The bellows:
If you don't find any defects, you should try replacing the MAF. Make sure you get the exact same part number you had before, otherwise you may require ECM reprogramming.
Lastly, you might take Bisi up on his offer.
07-03-2007, 01:55 AM
Yea i Though it was the MAF too. I dunno, if u can get me some directions on what i can do to check some of those things that would be great. Thanks for the advice though! really backed up what i had in mind.
07-03-2007, 07:54 AM
Your error codes tell us that your O2 sensors are sensing a lean condition and the DME is compensating by trimming the mixture to rich but has reached it's limit.
Typical causes:
Fouled MAF
intake vacuum leak
Mikefocke has a Boxter website with good basic troubleshooting for this problem with pictures. Check it out and then decide if you want to fix it yourself or pay someone else to do it. This is usually an easy fix that involves opening the engine bay and poking around the intake to see what vacuum hose is cracked or came loose. If everything is tight it is likely the MAF sensor is underreporting intake airflow info to the DME causing the engine to run lean.
Porsche mechanics often misdiagnose this as bad O2 sensors. In reality the O2 sensors worked perfectly. They reported a lean condition that could cause damage to your engine over time. Find the problem, fix it and then take her for a spirited Glendora Ridge run.
Good luck!
07-05-2007, 12:55 AM
i did put in a Evolution Intake... ANy instruction on how i can find the leak and fix it?? thanks
