Old 05-17-2007, 07:17 AM   #41
Originally Posted by djomlas
like getting an 08 model this year...
i still dont see how the stacked ones wouldnt fit on the earlier models tho, like 98 99...
They don't fit. That what these guys were saying. The stacked version came out for the 03 models.
porsche986spyder is offline   Reply With Quote
Old 05-17-2007, 07:20 AM   #42
Send a message via AIM to djomlas
is the oval opening for the tip larger on the newer models?
thats probably what it is
and thats not a cheap tip either, but looks sweet
http://i34.tinypic.com/157yslk.jpg
"I couldn't find the sports car of my dreams, so I built it myself." ~F. Porsche
Gemballa springs::litronics::Eurotech 18s(275/225)::B&M::MOMO wheel::
exhaust cutouts::EVOcoldair intake::OEM smoked tails & sidemarkers::
colormatched bumperettes::Top Speed Pro-1 exhaust::
my cardomain/pictures page
djomlas is offline   Reply With Quote
Old 05-17-2007, 07:29 AM   #43
07 Carrera S Cab
Boxtaboy's Avatar
The way the newer tips secure to the muffler is the difference. DJ, your chrome tip is actually a sleeve that fits over the already welded on smaller oval tip of the original muffler. It is secured by the 2 screws on the left and right side of the sleeve. On the newer 03 mufflers, they were made without any tips on them at all, so you just see a hole and bracket where the newer 03 tips would bolt onto.
Old 05-17-2007, 07:36 AM   #44
yeah i know that,. i actually had it off last weekend, wow did my car look plain and weird, maybe couse im used to it this way
i was just wondering why the stacked versio would not fit, i know that it would probably need to be either velded on, or secured another way, but would it make a problem when it comes to the actual opening on the bumper?
Old 05-17-2007, 07:44 AM   #45
07 Carrera S Cab
Boxtaboy's Avatar
Well, I'm not talking about having to cut and weld...I'm just talking about plug and play. The stacked version is bolted on the same way the other 03+ tips are secured from the same mounting point on the 03+ muffler. I'm sure, however, that with a good welder, you could make any tip fit if you cut off the old oval tip and then weld on the new desired tips, as boggtown has.
Old 05-17-2007, 07:55 AM   #46
thats what im talking about.
but im just interested to see if there would be a problem with clearance where the end of the tipo is, with the bottom of the rear bumper, the opening.
it should fit trough there with no problem, correct?
Old 05-17-2007, 07:59 AM   #47
07 Carrera S Cab
Boxtaboy's Avatar
Yes, I don't think there would be any problem of it fitting, if welded on. It should clear the bumper without issues, IMO. That stacked tip, however, is crazy expensive from the factory.
Old 05-17-2007, 01:21 PM   #48
There Is No Substitute.
rick3000's Avatar
Originally Posted by porsche986spyder
Well the guy rick3000 never told us what year his car was. I was assuming he had an earlier model.
I said that is a '99.
