Old 04-23-2007, 08:06 PM   #1
Send a message via AIM to djomlas
ummm....guys?
something weird happened...
i got some new numbers and letters cut for upcoming autocross, and i just wanted tos ee what they will look like on the car. put the numbers and letters on the passinger side, looks nice, then i decide to put the other ones on the drivers side and since the other car wasnt parked in our 2car garage i get to see better what it will look like from a bit far away...and to my suprise they will not stick to the door...then i took the numbers off the other door, same thing. i took the smaller letters and they stuck good on the botttttttom of the door, and they stick on the top right wher the window comes out, but nothing in the middle.
what is going on here?
btw, they stick on the both trunks, and fenders, but not on the drivers side door.
any help?
http://i34.tinypic.com/157yslk.jpg
"I couldn't find the sports car of my dreams, so I built it myself." ~F. Porsche
Gemballa springs::litronics::Eurotech 18s(275/225)::B&M::MOMO wheel::
exhaust cutouts::EVOcoldair intake::OEM smoked tails & sidemarkers::
colormatched bumperettes::Top Speed Pro-1 exhaust::
my cardomain/pictures page
djomlas is offline   Reply With Quote
Old 04-23-2007, 08:20 PM   #2
did you ever have any body work performed on the driver side door? Perhaps there is some body filler (like bondo) in it.
Larez2
larez2 is offline   Reply With Quote
Old 04-23-2007, 08:28 PM   #3
JAAY's Avatar
Funny you say this. I could swear that our doors are fiberglass of something. When you tap on them they dont sound like sheet metal to me.. Could just be me and my imagination?
JAAY is offline   Reply With Quote
Old 04-23-2007, 08:37 PM   #4
That's an interesting way to check for body work. I'll have to remember that..
-David
1995 Silverado V8 - Green/Tan (FOR SALE)
2000 Boxster S - Ocean Blue/Graphite Grey
2002 GSXR750 - Blue/White
http://www.darkoven.com/sig.jpg
David N. is offline   Reply With Quote
Old 04-23-2007, 10:29 PM   #5
Don't have a clue of what the doors are made of - but sounds like that old fashioned way to test if your car has had body work done. Run the magnet along the side, and if it doesn't stick - then Bondo's the culprit.
2002 Boxster S
C5150 is offline   Reply With Quote
Old 04-24-2007, 07:00 AM   #6
Yeah, your magnets SHOULD be sticking just fine. I've never had a problem.
http://farm1.static.flickr.com/211/4...7e5359a2_o.gif
Owned: 11 months
Miles: 78,000
Autocrosses: 22
Track Days: 1
http://www.crife.net
986 Girl is offline   Reply With Quote
Old 04-24-2007, 08:44 AM   #7
No issues with magnets sticking here. The doors are made of steel, not aluminum or fiberglass. Sounds like there may be some filler in one of your doors from previous bodywork. I wouln't worry about it.
John V is offline   Reply With Quote
Old 04-24-2007, 08:49 AM   #8
Perfectlap's Avatar
they stick on the trunks?
now that's weird because those are made of Alluminum and not steel like the doors and fender panels. Or maybe I'm confused..
BORN: March 2000 - FINLAND
Old 04-24-2007, 08:51 AM   #9
Ronzi's Avatar
Same thing happened to me in my old 914. I went out for my first run as car number "32", and came back as number "3". One of the cone-chasers picked up the missing "2" on one of the corners, and returned it to me.
Bondo.
Ronzi is offline   Reply With Quote
Old 04-24-2007, 08:56 AM   #10
Send a message via MSN to CJ_Boxster
If i ever have to use magnetic numbers, im sure ill have that issue cause while the bodyshop guy pulled out as much door dings as he could.. he had to use alittle bondo here and there, I think you should make smaller numbers.
Did you ever do a PPI? if so did body work ever appear?
Try lightly tapping the area in question with a head of a screw driver and see if you hear a difference as you tap along the surface... if the noise echo becames more deep, then could be a spot of bondo in there.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 04-24-2007, 09:15 AM   #11
That is indeed peculiar, I am quite sure my numbers will stick any where on the door, generally I place them right under the mirror. My numbers stick to the (rear) trunk lid, I keep the numbers on the underside of the trunk lid between events.
kabel
Orlando - 99 BMW M Coupe (autocross toy), '11 Mazdaspeed 3 (dog hauler), '99 10AE Miata (the new daily driver)
kabel is offline   Reply With Quote
Old 04-24-2007, 10:14 AM   #12
You are. All the body panels, save the bumpers, are steel.
