Removing rear bumper
Anyone have any instructions with pix as to how to remove the rear bumper?
I'd like to do this and get my rear diffusers put on right myself. The existing holes don't line up with the diffusers and using some of them that do kinda line up don't place it where I want it. |
Randall,
Beats me! You may need to ask Hans. I can't imagine it would be all that difficult, especially since some feel compelled to remove them just for a muffler swap. I'll be glad to lend a hand anytime as well. Did you check on the forums at renntech.org? There is a wealth of information there that is more technical, in general, than here. Toodles... - Mark |
Randall,
I have it on CD in a PDF. I'm a computer idiot, so I can't figure out how to separate the bumper portion from the whole chapter. It's a big file, but if your connection speed can handle it, I can try to send it to you. |
I wanna know to. Somebody post up. Jim is bound to know. He's the porsche tech. god on this forum haha
Btt ^^^^^^^^
I have the repair manual in PDF form too... but the diagram plus the instructions are really hard to understand. I might have my mechanic pull it for me and we put those on together!
I've removed my rear bumper before to install a sports exhaust. To remove the bumper, first remove the bumperettes by removing them with an allen key in the hole below each bumperette. Then, remove all the screws underneath the bottom side of the bumper. I think there are 6 in total along the bottom, plus one on each side located inside each rear wheel well. The final screws holding the bumper cover on are located on top of the bumper cover, but those can only be accessed by removing the rear spoiler.
To do this, just manually raise the rear spoiler, push out the plastic pop rivets located in the black metal portion of the spoiler (you'll be able to retreive and reuse these once you remove the spoiler frame, as they drop into the frame), and pop off the painted top portion of the spoiler. After removing the painted top portion of the spoiler, you will be able to look down the hollow black metal frame of the spoiler and see two hex bolts. Remove these, and you'll be able to pull out the metal frame, which then gives you access to the screws holding the top of the bumper cover. Once this is done, the bumper cover is free, but remember to disconnect the electrical wire that connects to the license plate bulbs before fully pulling out the bumper cover. Tip: When putting spoiler back on, tighten the hex bolts that secure the black metal frame of the spoiler while the spoiler is in the fully retracted position. If you secure the bolts with the spoiler up, when you retract the spoiler, it will end up sitting a bit too high from the bumper, and it will look like there's a gap between the spoiler and the bumper when the spoiler is in the down position. Ask me how I know this? ;) |
May God bless you for these logical instructions. Much better than the German who translated the stuff I have on hand!
...oh, and don't forget to reconnect the wire to the license plate bulb before putting the bumper cover back as well. Ask me how I know this too! :D |
This is gonna sound ridiculous...How do you manually raise the spoiler?
Rear diffuser installation
Hi Randall,
I have purchased the same diffusers as you have and after trying to intall them with the bumper on the car I finally decided that this was not going to work as my hands were way too large to work in that confined space...I considered removing the bumper cover but after studying the way the cover lip and the lip of the heat shield come into play to secure the sheet metal screws for the diffuser it appeared that this was going to require a good deal of effort to replace all of that in one assembled piece...I decided to try something different that is to drill out the diffuser holes and attach it from underneath. I drilled through the three existing holes first with a very small bit to avoid chipping the diffuser and then came back the other way with a larger bit to make the hole large enough to allow the head of a small sheet metal screw to pass through...the idea being that you now screw the sheet metal screw from the bottom and pass through the threaded nut enbedded in the diffuser..use a screw that is narrower then the threads in the nut so you are not useing the threads but rather using the nut as the stopping point for the screw head to snug up the diffuser...worked fine and diffuser is nice and tight no gaps or rattles. now you are thinking what about the holes in the diffuser? This was the part I took a chance with thinking if it turns out looking like crap I throw away and am out a couple of hundred dollars, not the end of the world..but since the holes are not visible from underneath the only one you deal with is the hole in the neck of the diffuser closest to the tail pipe...If you look at the angle that the hole makes on the visible side of this piece it actually is a semi-circular opening which I touched up with a dab of touch up paint and you would think it looks like a machined little hole that appears as though is should be there...the holes underneath the diffuser are totally out of sight unless you get on your back and look at them from underneath the car...so I didn't try to plug them just left them alone.....one final advantage of this alternative installation method is if the diffuser ever gets chipped from road stones you can unscew it in about 5minutes repaint and reinstall in same time frame avoiding the job of removing the bumper cover and heat shield etc.....food for thought so good luck with your installation whichever method you decide to choose..... |
| All times are GMT -8. The time now is 10:36 AM. |
