Old 04-17-2007, 10:47 AM   #21
Send a message via MSN to CJ_Boxster
interesting, I had no idea that some abs systems were vented. Thanks.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 04-19-2007, 03:35 AM   #22
edevlin's Avatar
This is somewhat off topic, but does relate to braking. I was wondering if one should push in the clutch when doing hard braking from higher RMP's. It seems like if you dont, you are applying breaks to not only the wheels but the engine as well.
Ed
My Car Webpage
2000 2.7L Boxster 102K; TTP intake, headers, high-flow cats; Dansk high-flow muffler; Autothority ECU chip; TechnoTorque 2; Bilstein coilovers; Racing Dynamics strut brace; stress-bar suspension kit; Aasco lightweight flywheel, B&M short shiftkit; 18" wheels; spare tire delete; OEM GT3 seats; JL audio speakers and subwoofer; Alpine PDX-5/PDX-2 amps; Kenwood DNX8120 CD/DVD/Nav; litronics, deambered
edevlin is offline   Reply With Quote
Old 04-19-2007, 06:47 AM   #23
Ed
Hi,
You would normally want the engine to do some of the braking, at least initially. But, I am not a fan of downshifting for normal driving, just let the engine wind down in the gear it's in until the Revs drop and then shift to neutral and let the Brakes do all the work. This is because of excess wear to the Clutch and Drivetrain.
Let's assume that your Clutch has only so many shifts in it. Using them for Downshifting to stop uses a lot of these available shifts for Braking, not driving. Plus, engaging the Clutch when the car still posesses a lot of inertia, places a strain on the Clutch, Synchros, Tranny and Axle Shafts, CV Joints, and the like, shortening their Service Life.
Brake pads are cheap - $150-$200, while the Clutch is $400-$1,000. As soon as you've bled off a lot of the inertia in the gear you're in, say 10-20 MPH, shift to neutral and use the Brakes until the car comes to a stop. Downshifting is unecessary, except to please the ears or impress that young Philly at the Stoplight. Both important, but at the cost of replacing components before you'd otherwise need to.
Of course, all this goes out the window in an Emergency. In this case, do everything you can to stop in as short a distance as possible - Downshift, Brake, even throw out a Boat Anchor if you have one.
But, in normal driving, you'll extend the life of your Drivetrain if you adopt the practice I've outlined above. Anticipate your stops, let Gravity reduce your inertia as much as possible and add the Brakes to bleed off the final amount of energy til you come to a full stop...
Happy Motoring!... Jim'99
Old 04-20-2007, 09:08 PM   #24
Brake fluid
If you brakes are getting hot, it could be a couple of things. And there are a couple of things you can do to prevent it or reduce it.
First you could have moisture in your brake fluid, and when your brake fluid gets hot the water will boil off and create air in your lines which is why the brakes fade, because the air is being compressed. So you would need to change out your brake fluid. The rule is once a year...and you would be surprised what kind of crap builds up after only a year... And go with a good racing brake fluid.
Second, what type of pads are you using..Metal Masters will heat up quickly. I personally use Hawk racing pads on my 911 on the track, I have yet to get a brake fade. They disapate heat really well. So the quality of Brake pads is a factor as well.
These are two main areas where you will need to start. If you get brake fade after these are corrected, then you need to look at your driving habits...
Chris
Dohertycm is offline   Reply With Quote
