Old 04-10-2007, 01:54 PM   #21
Originally Posted by jl1252
dj,
I am pretty sure I was above the required speed for it to raise as most of the driving was on the freeway.
Another question, when I manually raised the spoiler I thought it was supposed to stay up until it was manually retracted? I know I manually raised it on the freeway, and when I came to a stop, it retracted automatically. What's up with that?
Jeff
If you raise it manually it should not go back down regardless of how much you slow down or stop. It should stay up until you press the button again. If you leave it on auto, the manual says over 75mph it should raise automatically and then lower somewhere around 60-50mph automatically. There is a manual switch that you can buy and have installed closer to you within arms reach if you would like to have more control over it. It basically relocates the factory switch to your dash area. Here is the web site.
http://www.boxsey.com/spoiler_switch/index.htm
This is good if you added an external fixed spoiler like me and don't want the factory one going up and down all the time.
porsche986spyder is offline   Reply With Quote
Old 04-16-2007, 07:56 AM   #22
Well, I took the car out again this weekend and apparently the spoiler is working again, raising and lowering automatically as it should. I didn't have to do anything other than drive it at the appropriate speed which I always love doing. Man I love this car the more i drive it.
I did a viual inspection of the spoiler and noticed that it is slightly askew when in its retracted (down) position. What I mean is that if you are standing at the rear of the car looking down at the top right corner of the spoiler, the seam appears slightly narrower than the left side. There is enough clearance so that nothing is rubbing but definitley less clearance than the left side. When I raised the spoiler and looked at the right side I noticed that the standoff/strut that the spoiler is attached to is slightly loose, meaning I can manually shift it approx 1/8" in all directions. the bolts holding the standoff/strut in place are tight however. The left side is rock solid with no movement. Can the individual standoff/strut thing be replaced? I have a feeling it is the cause of irratic behavior and the seam issue.
Thanks to all that replied.
Jeff
jl1252 is offline   Reply With Quote
