Old 04-07-2007, 05:50 PM   #1
Help diagnosing a problem?
I have a 1998 Boxster with only 30,500 miles. Every time I start it after letting it rest for the night, a huge cloud of white smoke billows out of the exhaust. I had an oil change done with Mobile 1 about 2500 miles ago. What do you guys think may be the problem?
aaronrcheng is offline   Reply With Quote
Old 04-07-2007, 06:08 PM   #2
deliriousga's Avatar
I had the same problem with mine awhile ago and it was the oil separator. If so, you want to get that taken care of right away so it doesn't cause more serious problems.
1966 Wife White/Brown Top
Old 04-07-2007, 06:25 PM   #3
kool, thanks for the reply. How much did it cost you to fix it, just so I have an idea of how much its going to cost me.
Old 04-07-2007, 07:31 PM   #4
You may want to verify your coolant level hasn't gone down. If it has, you'll need to look for the source....like a blown head gasket. Also, if you can, try to smell the billowing cloud. Does it smell sweet? Sweet is coolant.
http://i19.photobucket.com/albums/b1...dingAvatar.jpg
Sold September 4th, 2007.
Rodger is offline   Reply With Quote
Old 04-08-2007, 01:21 AM   #5
definitely not sweet, it smells very, metallic... it smells the way I would imagine an engine would smell if it started to smoke *i know thats not a good sign*
Old 04-08-2007, 07:32 AM   #6
Porsche "Purist"
Paul's Avatar
How much oil is it using per 1000 miles?
1987 924S. 2002 996TT. PST-2
Old 04-08-2007, 02:50 PM   #7
Oil separator usually gives u same effect
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 04-08-2007, 09:33 PM   #8
Yea, the smoke clears up within 10 seconds and its good for the rest of the day. I'll take it to a mechanic as soon as I get a chance. Thanks for the replies guys, I'm glad to be a part of this forum!
Old 04-09-2007, 09:29 PM   #9
01 Boxster 40,000 miles
I've got an '01 boxster that has recently started making a bit of noise when i'm driving. the sound doesn't always come on, but is annoying when it does. it kind of sounds like a little rattle, like loose change, coming from the bottom of the car, perhaps the exhaust. but, it also sounds like it might be coming from the fan belt. sometimes when i close the doors shut, i can hear it rattle. any thoughts? thanks.
beatboxster is offline   Reply With Quote
Old 04-11-2007, 05:25 AM   #10
Just a guess, but I would check to see if something is loose regarding the heat shield for the exhaust :
Rattle sound coming from exaust
Nick
1999 986 ( Black )
1998 MB C280 ( Black )
1999 BMW K1200RS ( Yellow )
2005 Audi A4 ( Red )
