Old 03-17-2007, 03:37 PM   #1
Send a message via AIM to djomlas
head light mistery
last nite my passinger side headlight stopped working, only that little bulb inside is light up.
i figured its just the bulb, so bought a new one this morning and installed it,...same thing, no light.
high beams work good on both sides, but low beam nothing.
i checked the fuse under the dash, and swapped left with right, and still no luck.
i fiddled with the wires a little, just alittle left and right movement hoping it was bad connection around there, but still nothing.
anyone have any suggestions?
http://i34.tinypic.com/157yslk.jpg
"I couldn't find the sports car of my dreams, so I built it myself." ~F. Porsche
Gemballa springs::litronics::Eurotech 18s(275/225)::B&M::MOMO wheel::
exhaust cutouts::EVOcoldair intake::OEM smoked tails & sidemarkers::
colormatched bumperettes::Top Speed Pro-1 exhaust::
my cardomain/pictures page
djomlas is offline   Reply With Quote
Old 03-17-2007, 03:55 PM   #2
boggtown
Guest
Posts: n/a
Are you putting the bulb in the right spot? Theres no real diagram to the bulbs.
Old 03-17-2007, 04:16 PM   #3
hehe, yes i am. this is very frustrating
Old 03-17-2007, 05:37 PM   #4
turns out that the yellow clip that holds the connector on the car was loose, so when the headlight ws locked it gets pushed ot and looses contact.
fixed
Old 04-21-2007, 07:57 PM   #5
I'm having this same problem right now.
Passenger side low beam.
I swapped fuses, bulbs, jiggled every wire I could see, the pins on the headlight are tight, the connector on the car is tight.
Anyone have any ideas?
All other lights work on the passenger side, including side marker.
97 Boxster
eric95 is offline   Reply With Quote
