Old 03-16-2007, 10:33 AM   #1
Yet another dead battery thread; can't pop the front trunk
So after wintering for 3 months, my little 2.7's battery is dead. ...I know, I should have followed the great wintering instructions that MNBoxster and others have posted.
Firstly, I can't pop the hood (front trunk) to get at the battery.
In my 2001, I have found the red terminal behind the fusebox cover. But when I hooked up an old small 12V battery (for a home security system), all I got was a repeating horn honking from the Boxster.
Maybe there's not enough voltage (a meter said the little battery was 11V and it was old).
I'm heading to get a new battery but I thought I'd ask here in case I got back with the new battery only to find the same horn-honking but no hood-popping!
socratic is offline   Reply With Quote
Old 03-16-2007, 04:05 PM   #2
donv's Avatar
While you're out, get a cigarette lighter socket-style battery tender. Then you can plug it in when you're back and likely the hood will open.
donv is offline   Reply With Quote
