Old 03-12-2007, 03:25 PM   #1
Question
I have a 2000 Boxster w/ 65k miles. I pulled into the garage tonight after work, and as I walked around the back of the car, water just came gushing out. No lights were on the whole way home from work. I opened the rear lid and there was condensation on the water reservoir. About 10k miles ago, I had to replace the water pump. Could it have gone again? What do you think? Any ideas?
PorscheGirl is offline   Reply With Quote
Old 03-12-2007, 03:29 PM   #2
Water came gushing out from underneath the car?
Sounds like a NIGHTMARE. I'd cry.
Miss my Boxster
Bavarian Motorist is offline   Reply With Quote
Old 03-12-2007, 03:31 PM   #3
Sounds like it COULD be the cooling pump... might be one of the lines going to the reservoir... or the reservoir itself failed. I have heard of some reservoirs cracking....
Definitely DO NOT run the engine until you figure it out, or have it towed to a wrench.
2001 Boxster - Grey on Grey
1969 911T Targa - 'Stinky'
Old 03-12-2007, 03:46 PM   #4
Wel its hot there, If the water reseviour level is fine, then i would say thats condensation off your AC lines which is ok.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
Old 03-12-2007, 04:25 PM   #5
Brucelee's Avatar
Water or coolant? IF water, the a/c is likely just taking its usual dump. No worries.
Coolant, well, it is off to the mechanic you go!
Brake fluid? Call the tow truck.
Let us know what you find out!
Rich Belloff
