Old 05-26-2023, 11:06 AM   #1
Wtb 9x7 shifter
Wtb low mileage 9x7 shifter for my 2001Boxster S.
Found a 49k 997 shifter so I’m good, if possible please remove the thread although the private messages have been interesting 🤨
Jiminmaine is offline   Reply With Quote
Old 05-28-2023, 09:04 AM   #2
Ebay has some in the $200 range. I was shopping them and ended up with a cheap short shifter kit. The 987 is likely smoother but with a bit more slop.
wiebuschk is offline   Reply With Quote
Old 05-28-2023, 10:53 AM   #3
Shifter
Thanks for the reply, I’m probably headed in the same direction as you went, maybe bens shifter.
Old 05-28-2023, 06:01 PM   #4
Ben's is quality. I had to tweak mine to make it work but I didn't invest in Ben's because I did not know if I would like it. He has a real cool tall shifter with a round shaft that can use aftermarket knobs.
Old 05-30-2023, 01:55 PM   #5
I bought the ebay special for about $50, it was a pain to install as even though it said it was for a 986 I had to modify a bunch of things to fit it in. After that, I found that it was WAY too short of a throw (don't want to wreck the synchro's) so I've modified it again to make it less short. Probably about 20% less than stock, rather than the 40%+ that it is by default. I'll probably go with Ben's as a replacement.
redpepperracing is offline   Reply With Quote
Old 06-01-2023, 10:27 AM   #6
Educate my on how a short shifter can hurt the tranny. The bottom lever is longer which means the handle does not have to move as far. Is it not going into gear properly?
Old 06-01-2023, 11:26 AM   #7
A highly respected Porsche mechanic warned me that it was too short, that you need to be 'gentle' with the shifting. After reducing the 'shortness' of the ebay shifter, I would say it's not noticeably longer in throw, but it is smoother. Purely subjective, but it feels better.
Old 06-01-2023, 02:17 PM   #8
I shift like a geezer anyway! Im not crazy about the feel of mine. I found a deal on a 987 shifter today. I may put the upgraded bushings on it for tightness. I will update you on the outcome.
