Old 08-08-2021, 09:00 AM   #1
78F350's Avatar
Jon in Ok's 2000 S Junk Car
USA Shipping Only.
I have received a few requests for wiring harness parts already, so I might as well list the husk before I haul it off for scrap. Most of the high demand parts are already gone or worthless due to wear or damage.
It's a 2000 Boxster S that had a collision or two in the past and a few rough 'agricultural events' when I tracked it, so the body as a whole is not great for rebuilding, but I can cut/drill/detach body parts if you have a way to pick them up or can arrange freight to where I can just drop off a pallet with your paperwork in Muskogee or Tulsa.
Small parts and wiring connections are easy and cheap. Just let me know want you want and I'll probably send it for a few dollars over shipping cost.
I also have boxes and boxes of parts from other 986s including parts from bad engines, parts of seats, tops, doors, etc. Don't hesitate to ask and I won't hesitate to say no. I might even part with some 914 stuff or BMW R50/5 airhead scraps (not much left).
Help a parts hoarder clear some junk out to make room for more junk.
Old 08-08-2021, 11:00 AM   #2
Were you going to crush that as is or did you still have parts to remove before then? The uprights (specially the S rear), rear subframes, radiators, taillights and fenders are sought after by the racing community. The dme is worth keeping too
Depending on the part number, that abs pump is worth some money too
Woody
Old 08-08-2021, 11:52 AM   #3
Did it have heated seats? If so interested in the switches and as much of the wiring from the switches back (as much as reasonable)
2000 Boxster Tiptronic
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
1986 944 (gone but missed)
Old 08-08-2021, 12:29 PM   #4
78F350's Avatar
Yes and no. I pulled two seat frames out of it that were heated seats and have the wiring, but that car did not have heated seats as an option. I have an '01 that I plan to strip next month that does have the heated seat option and I can pull much of the harness from that car ---probably in a few weeks.
Old 08-08-2021, 12:43 PM   #5
78F350's Avatar
Were you going to crush that as is or did you still have parts to remove before then? ...
What happened is that I ran out of room for stuff. The garage is full of engines and motorcycles, the driveway has no more space for 'mostly operational' cars and the hidden corners of the yard have parts cars and future projects. When I got a rat infested 924 a few weeks back, so that I could use the faux Fuchs wheels on a 914 project, I had to put it on the back patio. ...
The point that I'm getting to is that I need the hulk of it gone and hope to have it done by next Friday in whatever condition it's in. I'm planning to roll it over and strip as much of the undercarriage off as I can before I scrap it. I want *some* of the parts for myself, but in reality I probably have all those parts tucked away somewhere already.
Old 08-08-2021, 02:27 PM   #6
I am in no rush. I created a setup for adding heated seats using the factory switches to either factory seats or adding aftermarket seat heaters. Finally found out the factory relay under the seat is actually a microchip, which makes sense. What I would like is a set of switches and the wiring that hopefully just go to each seat heater relay, but that wiring is most likely part of a bigger harness.
I have a car I need to add my setup to but am out of switches at the moment & harness.
2003 Boxster
2003 996 C2 Cab
2002 996 (SOLD)
Old 08-08-2021, 03:45 PM   #7
78F350's Avatar
I'll get a good look at it in the next week and figure out how much of the harness I can pull without getting deep into the main loom. I'll let you know.
Old 08-08-2021, 04:07 PM   #8
If you run into some Aerokit 2 (GT3) side skirts let me know!
Javi Cooper is offline   Reply With Quote
Old 08-08-2021, 06:41 PM   #9
78F350's Avatar
If there are any Aerokit 2 cars in my area, Rick (Redtele58) will probably snag them before I can.
The wiring harness is mostly out now. Interior and dash parts are out. Trunk stripped bare. Fuel system is probably next. Wednesday I'll roll it over and pull everything off the bottom. Here's some of it:
Old 08-08-2021, 07:03 PM   #10
RedTele58's Avatar
Originally Posted by 78f350 View Post
if there are any aerokit 2 cars in my area, rick (redtele58) will probably snag them before i can.
Prolly so...
Old 08-09-2021, 04:10 PM   #11
PLP
PLP's Avatar
Things I need:
spoiler (mainly the plastic part that had broken clips)
wheel wells (front/rear)
windshield cowl (if that is how it is called - the large plastic cover under wiper arms)
driver side bracket holding the corner light (under the bumper)
radiator fan
some random brackets
maybe underbody covers
let me know how to reach you over the phone - maybe I can get something from you
PLP is offline   Reply With Quote
Old 08-10-2021, 05:55 AM   #12
Originally Posted by PLP View Post
Things I need:
The 2003/04 have a different spoiler cover than 97-02. Hopefully he has a 03/04 from another car, otherwise prepared to spend some $$$ on eBay for a used one. I highly recommend using caulking to secure the cover down as those clips are very brittle at this age. You want to use caulking and not glue in case you need to remove it in the future.
Woody
Old 08-10-2021, 09:05 AM   #13
78F350's Avatar
Things I need:
Piotr, I have your email address from when you got the muffler. That's the best way to contact me directly. I just sent you an email regarding parts.
Subject: "Jon's Boxster Parts - 986 Forum"
Old 08-10-2021, 09:47 AM   #14
PLP
PLP's Avatar
Would caulk/glue be enough to hold it in place?
Except clips it is intact... so I though - heck, maybe I should go the "redneck", or HelpmeDIY route and simply glue it.
Old 08-10-2021, 09:49 AM   #15
78F350's Avatar
The 2003/04 have a different spoiler cover than 97-02. Hopefully he has a 03/04 from another car, ...
I'm still hoping to get a good title for my '04, but the seller keeps saying "It should be here next week." It's looking more like a parts car every day, but the spoiler cover is already gone.
Old 08-10-2021, 09:57 AM   #16
PLP
PLP's Avatar
I got your message.
Here is what I need
986 504 393 00, Cover
996 505 535 00, Retaining strip
996 572 563 06, Cowl panel covering
996 504 203 06, Wheel-housing liner
986 504 609 02, Upper part (spoiler, 03+)
Also, not sure if there is anything missing from rear wheel well after removing skirts.
It seems there is a gap on the front of the rear wheel well. A cover shell be there?
Old 08-10-2021, 10:41 AM   #17
Sorry to hijack your thread Jon
I caulked mine over 5 years ago and have gone as high as 140mph
Woody
Old 08-10-2021, 07:24 PM   #18
OMG! It's almost as if he's in EVERYONE'S area!! He already snagged a couple from me.
Rick, I still have my Aerokit 1 skirts. Offer to trade for (one of) your 2's still stands
Old 08-10-2021, 08:27 PM   #19
Control Arm w/good ball sockets for roof
Hello,
Sent you a PM for Control Arm w/ good ball sockets for the roof.
Thank you
t2-bxtrs is offline   Reply With Quote
Old 08-11-2021, 02:25 PM   #20
78F350's Avatar
I unbolted the struts and drained the fuel, then pulled it over with the Dung Beetle. Now it's easy to strip the underside.
