04-15-2016, 06:39 PM
WTB: Heater Control
Dealer was suppose to fix this but he reneged.
So now I have to try and get it repaired/replaced.
Pelican has a replacement face.
Has anyone ever tried this.
Cheers!
My Beast 2004 Boxster SE #0174
- 3.8 with all the internal goodies, Under-mount Pulley, IPD Plenum, 996 Intake, Softronic Tune, 987 Factory Sport Exhaust, skid plates, IMS solution, Ohlins R&T, RSS Toe Links, Camber Plates, Michelin Pilot Super Sport on all 4 corners, Alpine Double Din c/w new speakers & amps.
04-15-2016, 07:59 PM
still plays with cars...
Six speed 2000 Boxster S
04-15-2016, 08:44 PM
Had the same issue with mine - bought the module master Boxstersteve has highlighted and worked like a charm. It's an extremely quick and easy fix.
04-18-2016, 09:04 AM
Does the new one screen look the same as the original?
The icons look different on the replacement one?
04-18-2016, 05:33 PM
The script is slightly different on the Module Master kit. Can't speak to the Pelican kit though.
04-19-2016, 03:15 AM
996/986 LCD Display unit wth connectors (replacement kit)
i used this one when I did mine. Looks original, or at least not Audi. Keeps the Manuell
Reason: Added info.
04-19-2016, 06:41 AM
I purchased a replacement used HVAC unit from Ebay for about $100....it was an easy swap.
04-19-2016, 09:31 AM
I've got the entire replacement module. Out of a 98 boxster. $100 sounds about right, I haven't priced it on Pelican.
04-19-2016, 09:39 AM
Sent PM
Thanks Bart
04-19-2016, 12:33 PM
I don't remember exactly, but not all modules can be swapped (even though they appear identical). One of the pins was changed in the later 986s. Double check your PNs.
04-19-2016, 12:52 PM
I've seen compatibility issues, even when part #'s match. I'd recommend the OP fix his rather than trying a swap. The cars VIN is stored in the climate control unit, but I'm not sure what this affects as I've seen plenty of successful swaps (though more unsuccessful).
04-21-2016, 05:38 PM
The dealer says I will need a unit from a 2003 or 2004 only.
That's a shame.
Thanks anyway.
Cheers! Bart
04-22-2016, 04:50 AM
That's a shame.
Thanks anyway.
Cheers! Bart
I'm 90% sure a 2002 will work too. I forget if 2001 will though. I think I've seen both styles in a 2001. The whole unit is black on the early style and there will be four wire connections plugged into the back. The later style has the black face plate but the rest of it is a light tan color. It also has four spots on the back of it for wire connection, but only two are used.
Woody
05-07-2016, 06:32 PM
Well I can't believe I did it. (I'm not good with electronics)
It was one of the easiest things I have ever done.
It took approx. 30 min.
I t has the same script as the original.
I got it from 914 Rubber.com
Here is what it looks like.
