10-31-2015, 05:19 PM
I am my own mechanic....
May I recommend a product?
Absolutely fantastic.
'08 VW Touareg T-3 wife's car
11-01-2015, 03:21 AM
2003 Base 5-speed
Does it work on.......
very heavily coated, old brake dust? I have tried Maquiars all wheel cleaner, Car-Pro Iron-X and P21S gel. All to a good job of removing light or new brake dust. My rims seem to have old dust "baked" into them. I have tried adding light mild abrasive scrubbing as well. Gets them to about 85% of the result I want.
11-01-2015, 04:04 AM
Try SONAX.
Couple years ago I seriously thought the wheels would need resurfacing, powder coating. They looked that bad. Scrubbing them was little help.
Sprayed on SONAX, available Amazon etc...
Spray it on, watch it change color from green to red, 3-5 minutes, spray off w/high pressure water at coin operated car wash.
They came out looking like new, and I have spoke type wheels.
11-01-2015, 04:29 AM
Been using sonax for quite a while and it is a great product. I try to take the wheels off about every 15,00 miles ( which comes pretty quick for me ) and inspect the brakes, tires, etc and give the wheels a good cleaning with sonax and then a couple of good applications of wax.
11-01-2015, 04:58 AM
I swear by P21S...
11-01-2015, 05:06 AM
2003 Base 5-speed
Well, what's one more product to try......
...in the search for perfection?!?
Here's what mine look like:
11-01-2015, 06:05 AM
What I'm talking about.
After repeated scrubbing w/various products still that had that type niggling trace, which is why I thought it needed resurfacing or repainting.
Sonax removed it.
Problem solved.
11-01-2015, 07:06 AM
2003 Base 5-speed
Sonax removed it.
Problem solved.
Ok, thanks! I'll gave Sonax a try. BTW, I just went out and gave the trouble spots a mild wipe with Maquiars compound. Seems to work pretty well. When I have time I may go back more thorougly.
11-01-2015, 08:19 PM
If you are searching for perfection, you need to fix your centre caps! :-) They aren't concourse ready like that.
11-02-2015, 02:36 AM
2003 Base 5-speed
Haha......"in search of perfection" was a tad tongue in cheek. I'll not be entering any concourse events soon. I just want fairly clean wheels. And I'll not be spending a few hundred dollars on new center caps!
Although I did spend $17 on black valve stem covers with colored crests! And one of the crests fell off on the first day (not good, Suncoast).
11-01-2015, 08:10 PM
Originally Posted by ekam
I swear by P21S...
Hey ....ran out where in TO can it be had?
986 00S
11-02-2015, 02:38 AM
2003 Base 5-speed
Got mine...............
Through Autogeek.net. Not sure you can run out anywhere for P21S
11-01-2015, 07:25 AM
Griot's Garage heavy duty wheel cleaner is the bomb!. It also smells good
Tried P21 and sonax and prefer Griot's Garage
11-09-2015, 06:03 PM
2003 Base 5-speed
Tried P21 and sonax and prefer Griot's Grage
Winner! For me, Griot's garage is the best I've tried. Took off most of the baked on brake dust with just a spray on and agitation with a bristled wheel brush and rinse off. For some of the really tough spots in the crevasses, some medium scrubbing with a non-abrasive pad was all it needed.
I just received my Griot's Garage and was so anxious to try it I went out and used it in the dark, so no pics yet. Maybe on the weekend - when I can apply a coat of Rejex, too.
Thanks for the recommendation, Jay!
11-10-2015, 12:59 AM
This is the Purple cleaner from Orchard Supply at full strength, with a little detailing in the corners. I need a brush for the lug nuts, and will be happy.
I like the idea of the wax on the rims, I think that will help the weekly upkeep. What kind do you recommend?
11-01-2015, 07:35 AM
Just wax your wheels and very little dust will adhere and what does will come off with water.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
11-01-2015, 07:41 AM
2003 Base 5-speed
Yep, but no sense waxing them until they are cleaned up to my satisfaction. Some wouldn't care, and my car is 12 years old and hardly ready for a concours - but clean, sharp wheels make any vehicle, no?
11-01-2015, 08:47 AM
The slicker a surface is the less sticks to it. I use old clay bar for tough wheel stains. Then wax.
11-01-2015, 09:08 AM
2003 Base 5-speed
Thanks for all the suggestions! And Timco, I didn't intend to hijack the thread. BTW, your wheels and calipers look awesome. And your Anniversary edition in GT Silver metallic with cocoa interior is one of my favorite color combos of all 986's. Just a beautiful Box!
HTML code is Off
