Old 05-22-2007, 04:22 PM   #11
KevinH1990
KevinH1990's Avatar
Originally Posted by shaman1204
If you don't have ramps, you can do what i did. I went to Home Depot and purchased two 2x10s, had them cut four 18" pieces and four 12" pieces, took them home, screwed them together and had ramps for around $10. The extra four inches all the clearance I needed.
A set of Rhino Ramps is not much more expensive and you will have them for years.
I encountered one problem. A friend and fellow Boxster owner had visited to observe the oil change process. When I was driving my car off the ramps one of them shot out from under the wheel and nearly hit him. I don't know why it happened. I suspect it was a combination of agressive tire tread pattern and applying a little too much gas.
KevinH1990 is offline   Reply With Quote
