You'll also want to consider your particular situation. Do you live in an area that is regularly plowed or do you need to get over some fairly deep snow at times?
Here in Colorado, the main roads are normally plowed pretty well but my neighborhood is totally ignored. At times I can't get out of my driveway let alone down the street without some decent ground clearance. If there's more than 4" on the road, the Boxster turns into either a snow plow or a sled no matter what tires you're using, neither is much fun.
