Originally Posted by 2000SoCalBoxsterS
That's incredible! How did you make your own lower stress bar?
HI, I used a 3/4 x 24 inches long diameter aluminum bar, made 2 flats at each end about 2 inches in length, giving a total thickness of 9/16, then i measured the distance between the 2 bolts, drilled the bar at each end to clear a 3/8 bolt and that is all.
OH, the distance between the 2 existing bolt on my car was 22 1/4 center to center.
