Old 05-19-2007, 08:41 AM   #2
rick3000
There Is No Substitute.
rick3000's Avatar
It would not be too hard to pull the cable up under the dash near the alarm, but you will probably have to drill a hole in the dash. You best bet would be to run it through the center console and place it up behind the driver/passenger area. Also, you should look into making a frame that fits around the GPS.
