Old 05-16-2007, 09:10 PM   #1
MNBoxster
Hi,
The Engine Compartment Fan is just that, a Fan to vent hot air from the Engine Bay.
Generally speaking, it comes on to supplement the natural airflow through the Passenger side vent if the Engine Bay Temp exceeds 180°F, but not always.
It's primary purpose is to keep the Fuel and Charge cool by keeping the Engine Bay cool. It is the job of the Cooling System (Coolant, Coolant Pump, 'T'stat, Radiators and Radiator Fans) to keep the Engine cool, so don't look for or expect a Temp Gauge reaction from the Engine Compartment Fan, it won't happen.
It is controlled by the DME which uses several sensors and/or parameters in determining whether or not the Fan should be energized. The actual Engine Bay temp is only one component in this determination. So, it's actually possible to exceed 180°F in the Engine Bay and not have the Fan come on. Because of this, it's very difficult to establish a pattern when the Fan will come on or not
It uses an NTC Thermistor mounted between the Intake Runners for Cyls. 1 & 2 to determine the Engine Bay Temperature and is controlled via a Relay (#8 in the #2 Relay panel (in the Trunk)).
It is fairly common for the Relays for all the Fans to fail as the Fans themselves are pretty high current items. If you suspect your Engine Compartment Fan is running too much, or not often enough, you should swap out the relay. Hope this helps...
Happy Motoring!... Jim'99
PS - The Oil is responsible for removing 60% of the Engine Heat, which it then exchanges with the Coolant in the 'Oil Cooler' (Oil/Water Heat Exchanger). The Coolant then carries this heat to the Radiators to disperse to atmosphere. The Tiptronic S cars have an additional O/W Heat Exchanger for the Tranny.
