Thread: A Few Questions
Old 05-15-2007, 05:21 AM   #15
2000SoCalBoxsterS
From your pictures I can tell you with no doubt that your car is messed up. It was either in a serious accident or a major A-hole did work on that car.
That Triangular plate under the rear is an integral component of your rear suspension and acts to add rigidity to the rear of the car. It is not supposed to be bent around the sway bar. It does have a long channel opening for the sway bar to fit into and show through a little bit. The car must never be driven without this plate or with a damaged plate.
2000SoCalBoxsterS is offline   Reply With Quote
