Originally Posted by insite
does it make the sound regardless of whether the car is in gear? FYI, when my water pump went, it made no noise; it just started to leak. still, though, i'd remove the panel behind the seats, start the car and listen. it could be a water pump, alternator, power steering pump, ac compressor, idle pulley, etc. it should be fairly apparent if it's one of these ancilliaries.
Hi, Yes it makes the noise regardless .
Thanks guys, I know it's difficult to pin point where the noise is coming from without actually hearing it, but your opinions are always helpful.
