Old 05-12-2007, 11:53 AM   #2
CJ_Boxster
Send a message via MSN to CJ_Boxster
When the vibration goes... is that only on cold days or nite in the 50's temp? and the vibration comes on warm - hot days and nites? If so, probably your front traction bars. Mine also vibrate but usually when its warm cause the nylon bushing inside become more smushy and i also hear a chatter coming from them, i checked them when i was under my car one day when it was really hot and sure enough they have the slightest amount of play which they are not suppose to have, they are suppose to be solid ****************en firm (excuse my language). No little tick tick noise should come from them even if your shaking the arm with your hand. Absolutly NO noise should come from them if they are in perfect working order.
EDIT: realized you have spacers... chances are your spacers are not very high quality and can easily cause vibration. Im sure someone on this forum has a link to a manufactor that make high quality spacers.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
