Ok, I fixed it. Apparently, the brown plug for the rear speakers came loose. Yes, it is for a CDR 220. I adjusted the Fader etc but I knew it was a loose or unplugged wire...I just hadn't had time to find it until yesterday. If you see my pic in the first post, you will notice that the center socket is empty and there's where the brown plug goes in. FYI when you pull the radio out with the radio tool, the wire for the brown plug is very short and you can barely have the radio out without putting extreme tension on the brown plug wire. I think somebody pulled the radio out and there's how the brown plug came loose.
Stereo sounds a lot better with rear factory speakers although I would rate the rear factory speakers as average (not like Bose or anything) but I am still pretty happ. Thanks again for all your help!!
