Old 05-06-2007, 02:49 PM   #13
Franco
Franco's Avatar
Originally Posted by MNBoxster
Hi,
Interesting.... Porsche has a TSB out 9/00 1715 1 noting the Oil Filler Hose between the Crankcase and the Service Unit (Oil Filler in Trunk).
It says: "Oil Filler Hose can crack causing the following conditions:
  • Check Engine Light
    Oil Leak on the Crankcase in the area of the Oil Filler Hose
    Rough running (rough idling, increased idle speed)
    As a result of the incoming secondary air, the following Fault Codes may be stored in the DME Fault Memory: P1123 to P1130.
    A new style hose was installed in Production as of August 18, 2000. In case of complaints, the new style Hose should be installed. PN# 996.107.254.03"
Sounds similar to what you're experiencing, especially with the sound you describe. Check the Crankcase for tell-tale signs, and if confirmed, send me a PM w/ your email Addy and I'll shoot you a copy of the TSB w/ replacement procedure.
There is also a TSB discussing P1123 and noting the proper voltage range of the MAF. It says:
  • MAF signal voltage:
    - If the value is between 0.92 V and 1.08 V, no replacement is necessary.
    - If the value is 1.15 V or above, replace MAF.
Run a test using a Multimeter and see what value it gives you. Hope this helps...
Happy Motoring!... Jim'99
Hi Jim, I'm trying to send you a PM but your inbox is full.
Thanks Franco
1997 Porsche Boxster manual
2018 Subaru WRX Sport Tech
2014 Honda CRV
2014 Mercedes Benz 350 ML
2015 Chevrolet Corvette Stingray manual
Franco is offline   Reply With Quote
