Old 05-04-2007, 02:03 PM   #18
blinkwatt
Send a message via AIM to blinkwatt
Originally Posted by MNBoxster
Hi,
The hydraulic line will have a Flare Nut fitting on it. The ones on the Calipers are 10mm, so I assume it's the same.
The change in Line and Union probably notes a change to whatever Nut is currently used and you most likely have to swap them all out...
Happy Motoring!... Jim'99
Jim,
It looks like my hydraulic line is held in by a push pin,see my pic,that's my exact one from my car. I was told that there are two types of hydraulic lines,the push pin and from what you say a flare nut fitting. The pic looks like a push pin design,please correct me if I'm wrong.
This is the part I will be changing it out with;
https://www.************************************************************/secure/PartImages/8E0721257F.jpg
Why in the world does Porsche use several different parts for the same application?
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
blinkwatt is offline   Reply With Quote
