Old 05-04-2007, 12:50 PM   #16
MNBoxster
Hi,
The hydraulic line will have a Flare Nut fitting on it. The ones on the Calipers are 10mm, so I assume it's the same.
The change in Line and Union probably notes a change to whatever Nut is currently used and you most likely have to swap them all out...
Happy Motoring!... Jim'99
