Nice work Insite,
You patiently seek out leading edge performance upgrades, act as test pilot, verify your impressions with instrumentation and lap times and share your findings with all of us. Bravo!
This is not bolt on fluff, but tested and verified with results. 2.5 sec on a track you already have wired is pretty good stuff. Just for kicks, if you had not made these improvements to your suspension and braking and focused only on the motor, how much HP increase would you need to get the same lap times? 50? 80? Interesting question don't you think? I suspect you are already outrunning most of the 987's in your area with a stock 2.5 motor.
Thank you again for sharing your findings.
