2002 Boxster S Front Camber Settings
For AutoX and track events, is there a way I can modify the front camber to improve turn in speed, without the use of aftermarket camber plates???
I don't want to get aftermarket camber plates since that will move me to a different group. I want to remain in the Stock category.
I know that the first thing to do is get a wider tire up front but that still does not solve the excessive outside edge ware problem on tires.
So can I make it at least a little better (more negative) from stock components??? I know that without aftermarket camber plates I won't get much negative camber out of the front wheels but can it be improved?
LRR
