Old 05-03-2007, 05:35 AM   #10
CJ_Boxster
Send a message via MSN to CJ_Boxster
Originally Posted by spark00
looks awesome CJ!!!! i'm painting my center console silver right now and hope it will come out as good as yours. any advice on installing center console back without scratching it?
Thanks, My advise to installing the console without scratching it up is making sure its cured really well before installing, then first fit the Shifter into the console. shift into different gears for easier angles then the e-brake may give you problems so make sure you have it pulled up really high and slip the console through then snap in the console cover for the side of the e-brake and push the 2 tabs downward with your fingers so they dont raise and scratch the surface up.
Who cares if your fingers get pinched a little, atleast the console isnt scratched... thats how i see it anyway. Good luck with that, show us pictures when your done.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
