Old 05-03-2007, 01:55 AM   #2
PMCHSS
I had the same rattling problem on my 2001 Boxster.It was the heat shields at the rear.There are three bolts holding each one on.If you lye down at the rear of your car and feel the heat sheilds you will see if they are loose.You may be able to tighten them but they usually rust around the bolts so you will need to replace them.
PMCHSS is offline   Reply With Quote
