Old 05-02-2007, 05:37 PM   #13
markab986
Originally Posted by SC986
If you/can you paint the carbon fiber what will the finish look like? Will you see the fiber or can it be matched in a smooth finish like the bumper?
Yes, you can make a super smooth finish.
It depends on the tooling/cure process, fill & sand, and the desired finish.
Most composite components will need some sort of buildup, insert, or stiffener in the hole areas to prevent cracking.
BTW...fiberglass is a composite material too!
markab986 is offline   Reply With Quote
