Old 04-30-2007, 03:32 PM   #2
porsche986spyder
That's crazy, you don't have to drop the engine. It does say in the instructions to remove the intake manifold, (left side/passengar one) but this is only to make the installation easier to get the new airbox into place. I would go some place else who can do it the way it is stated in the instructions. Not by droping the engine. There was someone else on this forum who installed a Power Flow intake, whci is basically the same type of cool air intake system and he did not even remove the manifold. He cut allot of plastic stuff out of the way from underneath, and was able to install it with any problems. You will have to remove the driver's side rear wheel and mud shield to get to that area I believe. If you do a search on this forum for Power Flow, you will find his step by step do it yourself instructions with pictures. Good luck.
porsche986spyder is offline   Reply With Quote
