04-30-2007, 08:14 AM
#2
CV boots
Originally Posted by ferris
I noticed a burning smell coming from the rear axle of my 2000 Boxster S, put the car on the jack and noticed 3 out of 4 CV boots are cracked and leaking grease all over the rear. I was told that if this goes unoticed, eventually all the grease will be gone and you'll need a new axle, about a $1K expense. The cost to replace the CV boots is pretty high - dealer quoted me $1K, my independent mechanic quoted me $450 ($100 parts and $350 labor). apparently the labor cost is hight to pull the axles out. Since labor is high my mechanic suggested replacing all 4 while you have the parts disassembled.
Make sure to inspect your CV boots often!
Will do...thanks.
