Old 10-07-2004, 06:55 PM   #10
Ad Sach
Ad Sach's Avatar
Originally posted by Automon
What about the tires?
Some folks over inflate the tires to 36-40 lbs - If they don't leak, I'd just park at full normal pressure and check once every 60 days.
Some folks leave the front trunk unlatched - incase the battery maintainer gets unplugged or chewed by mice you can still get to the battery. Your car goes into "power save" mode after a few days - even with the trunk open.
Others leave the trunk closed to keep mice and spiders out. With a 2002 or greater, you have that pull out thing in the fuse box, so I would latch the front trunk. Either way, close your windows.
I wouldn't put moth balls inside the car, etc. This is only for a few months(a few months )
- - - Bottom line - - - -
If you can stand not driving her, just plug her into a trickle charger, close the windows and doors, throw a sheet over her, and walk away.
Ad Sach is offline   Reply With Quote
