Originally Posted by spark00
how accurate are the oil level sensors? my oil level indicator on 99 model always shows oil level to be within max and min level but it's always at different place. close to bottom or min level when putting the gas in but almost at max level during other times. not sure if i can trust the sensor.
Hi,
IMHO, they're not all that accurate, others disagree.
But, in any event there are so many conditions which must be met to insure accuracy - Engine OFF, Car on Level Ground (do you carry a Bubble Level with you?), sufficient time to allow Oil to drain, Oil at operating Temperature, etc. that if you're one of the lucky few who has a Dipstick ('97-'03), refer to it when determining when to add and only use the digi-gauge as a convenience...
Happy Motoring!... Jim'99
