Old 04-25-2007, 09:21 PM   #2
DrRoentgen
Guest
Posts: n/a
Originally Posted by Allen K. Littlefield
Dr. R, the evo intake closes the chamber off so only outside air (cool air) enters the cone filter. I am not so sure if this is good or not because I don't know if the opening around the stock intake area allows for some air flow over the engine and cutting it off may contribute to high engine temps. Again, the more experienced here should chime in. Cooler intake air and a cool engine are both goals that are hard in a mid-engine car. I have also seen air scoops that would tend to ram more air into the intake. I think cooling air comes in the right side vent, over and down and out the bottom so the scoops would work on the right side too. Again, I am new to this and am learning so my info. may not be totally accurate but that gives others with more knowledge to post corrections. What ever the case, have fun with your car.
AKL
AKL,
I'm always learning as well, the sealed evo intake makes much more sense. I had read some corroborating information regarding the engine temps and de snorkeling. I'm hoping someone will post and comment on the following:
Does the snorkel taper accelerate the airflow?
Would shortening the length provide an advantage over just leaving the snorkel out?
If you shorten the length should the outer lip be enlarged and blended into the new end?
I worked on the car as a hobby all winter long in my own shop. I have enjoyed the car since the first day I drove it and improved it each year with whatever it has needed. Fact is I was so effective in my approach to perfecting my Boxster that I was awarded with a ticket this past weekend...
