The RoW suspension lowers the car slightly, which would naturally give more static negative camber.
My car is going in on Monday for an alignment. Specs will be maximum front negative camber, minimum rear negative camber, 1/8" total toe-out front (8 minutes per wheel or 16 minutes total toe out), zero total toe rear.
