Thread: Spark plugs
Old 04-25-2007, 09:00 AM   #22
MNBoxster
Originally Posted by John V
I cannot think of way that high-temp anti-seize between the plug's common terminal and the engine could interfere with the series resistance of the spark plugs. Can you please educate me?
Hi,
You're most probably right, but using a Hi-Temp AS w/ high metal content (usually Copper) can effectivelty increase the surface area of the Ground or Common terminal with the Head by making contact (via a brige through the AS) to the back side of the threads. Would this interfere? I don't know, but I am just postulating a possible cause to the Lister's observations. This is why I said that it could (possibly) interfere.
An Insulator (regular AS) probably would interfere with such a function. The Spark would still be OK due to the high voltage involved which would readily overcome any added resistance...
Happy Motoring!... Jim'99
