Old 04-23-2007, 07:57 PM   #3
speedfreak
Originally Posted by bmwm750
Now, given that these blocks really arent rebuildable, would you open the motor and install lower compression pistons and hope the cylinders hold
I've seen companies that wil increase the displacement of the engines by fitting larger cylinders and pistons. The biggest yet was a 4.0L TT engine (there's no replacement for displacement AND lots of boost). If you had this done, they could fit low CR pistons at the same time. If you want names though, I'll have to get back to you.
speedfreak is offline   Reply With Quote
