Old 11-30-2002, 03:05 AM   #1
mjbliemel
mjbliemel's Avatar
Question Tightening the top question
OK. I have the instructions on how to do it, but I can't figure out where this "bolt" is that you have to tighten. Anyone have a picture of that? It would be greatly appreciated.
"In the rear left and right side there are two cables, one each side. Follow the cable down to a ball socket and you will see a 100mm bolt. By turning the bolt counter clockwise it will tighten Do not do too much because this affects where the top meets the windshield. Usually a half to one full turn on each will do the job."
Also, in what position should the top be when I look for the bolt and do the tightening?
Thanks in advance!
mjbliemel is offline   Reply With Quote
