Old 04-17-2007, 11:48 AM   #3
Strawfordt
Checking the Clutch
Insite
Originally Posted by insite
if you want to double check, put it in fourth at about 2200 RPM's and floor it. if the clutch doesn't slip, you're alright.
Thanks for your fast response. I assume the 2,200 RPM's in fourth is the worst case scenario and therefore the most likely to cause slippage...correct?
Windsor, Ontario Canada -- Silver 98 Boxster with black interior 90k kms -- Weekend toy, summers only
Strawfordt is offline   Reply With Quote
